Indexing a Driveshaft?
Old 08-24-2009, 12:00 AM
Bull's Avatar
Default Indexing a Driveshaft?
I hope I am using the correct term. I am converting my '95 Formula from auto to T56. Since I have to remove the old, rusty steel driveshaft, I figure I might as well replace it with the nice aluminum one I saved from my old '92 TA. I was looking in my factory service manual today, and it makes a big deal out of making sure that you mark how the driveshaft is before removing it, then install it in exactly the same position.
Now, if installing a different driveshaft, this obviously can't be done. Does it really matter? I had the stock steel shaft out once before and did not worry about what position I reinstalled it in...did not seem to cause any vibration or anything of that sort.
Old 08-24-2009, 08:45 PM
adam1803's Avatar
don't worry about it, like you said since its a different driveshaft there is no way to index it. If it vibrates, just turn it 180* and see if it smooths out.
Old 08-24-2009, 08:53 PM
Bull's Avatar
Thanks for taking the time to respond, I appreciate it.
