NOS launcher or NX max 3
7 Second Club
i'm looking at both of these for the ability to individually progress 2
seperate/ different systems...
anyone have any experience using these in this instance? both are about the same price and are small enough controllers to be able to mount easily and program off a laptop....
i like the NX max 3 a little more cause it has the ability to interface with a davis traction controll modual which is pretty sweet if i end up buying one.
if you havent used atleast one i dont need your comments about them.
thanks
tyler
thanks
tyler
7 Second Club
i'm running some pretty large systems and cant knock the power down low enough without leaving the starting line on 0* timing.... so im going to progress both systems with a smooth curve and then use the digital box for some fine tunning...
i had the car mph 125 with a 1.46 60' skating all around at the 330 on...
this was leaving on 3 degrees timing on 1 system...
in elimations it left extremely hard then about 1.05-1.09 seconds in to the run it set the front end down and spun leaving a 1.499 60' to complain about..
needless to say went out first round.
