Questions on what nitrous kit to buy!
Old 08-24-2009, 10:52 PM
juicedls1's Avatar
Default Questions on what nitrous kit to buy!
I got a 04 GTO with a built 6.0L (compstar rods, crank,-13cc diamond pistons, turbo grind cam, port and polished 243 heads with arp studs, victor jr intake with elbow, 60lb injectors, Gss340 intake pump wit Kenne Bell BAP etc) currently a rear mount turbo car wit 9.0 compression. I plan having the heads milled as much as possible and still be safe to get the most compression out of it. It is a 6speed car. I want a 2 stage system preferably dry so i dont have to worry bout fuel puddling as much. Im looking towards a combined total of 250-300hp worth of nitrous. Maybe 100 off the line then another 150 bout midways thru 2nd gear.
What n2o kit and fuel system would yall recommend for me?
Is the Harris interface the easiest to tune with a dry system? It ll be tuned with EFi live. I will DD this car and race the car NA quite often.
Thanks in advance!!!
Old 08-24-2009, 11:00 PM
juicedls1's Avatar
O and the car will be tuned on a 2-bar speed density tune not unless a MAF would be much better...
Old 08-25-2009, 09:48 AM
Nick@HSW's Avatar
If you're going speed density you will be somewhat limited in the dry nitrous department. Shoot me a PM, lets go over your set up and goals and I can help get you going in the right direction.
Nick
Old 08-25-2009, 10:11 PM
juicedls1's Avatar
PM sent
