oil leak after h/c
oil leak after h/c
sup guys i just finsished my tsp trq 3 and prc 215 install and on the test start oil is leaking right above the oil filter is there some trick for droping the pan or a nother way to seal it i have tried tighten the bolts around it and its still leaking any ideas ill post up some vids and pics whens shes done
also i reinstalled my water pump and on start up it broke the shaft and now leaks water so i have to go buy a new one should i upgrade to a higher flow pump and if so what pump would you buy ?
thanks guys i have done nothing but wrench on this thing for 6 days and i want it done
