Oil Pressure Temp Gauges Electronic?
Oil Pressure Temp Gauges Electronic or Mechanical gauges?
I have a carbed Ls1 that I'm putting into a Miata. I have the Oil Pressure sensor with the two wires coming out, and the Water Temp Sensor with the 3 wires coming out. Any suggestions as to what gauges I should use (autometer?) and how they should be wired? Should I ditch the electronic oil pressure sensor and use an oil actuated oil pressure sensor? All suggestions would be appreciated. Thanks
Thanks for the interest, but I bought summit's machinical oil pressure, water temp, and ammameter gauge cluster kit. Cheap, straightforward and probably more accurate then using electronic sending units
