sway bar issue with moser 9 inch
Old 08-30-2009, 12:01 AM
chucks ss's Avatar
Default sway bar issue with moser 9 inch
what sway bar can i get for my moser 9 inch the stock 10 bolt sway bar is not working the way i want it to its too small thanks
Old 08-30-2009, 03:15 AM
roy
roy's Avatar
I purchased a set of BMR swabar mount brackets and welded them on . No custom swaybar needed then . These will allow you to factory style swaybars . You just pick the diameter of bar you want.
