Doing clutc. Should I Replace Rear Main Seal?
Old 08-30-2009, 08:49 PM
Eatinstang4life's Avatar
Default Doing clutch. Should I Replace Rear Main Seal?
Just wondering if I should replace the rear main engine seal while I have access to it. My car has 70k miles on it. The seal looked great and dry when I first pulled the flywheel off but now after two days of sitting I notices a tiny bit of oil around the bottom of the seal concerning me. Is it hard to replace these?
Old 08-30-2009, 09:26 PM
bearcatt's Avatar
Yes if you have it all apart you might as well change the rear main seal.
It's not that hard.
Old 08-30-2009, 09:31 PM
Is it easier to take the cover off and replace the seal?
Old 08-30-2009, 09:36 PM
bearcatt's Avatar
Not sure what you are asking ?
I just drained the motor oil, pryed the oil seal and drove another one on there.
Old 08-30-2009, 10:54 PM
there is a cover just like the front timing cover on the rear of the engine that the seal is housed in.
Old 08-31-2009, 12:06 AM
bearcatt's Avatar
Oh I see what you mean now.
I didn't even think about removing the housing.
I just used a seal puller and screwdrivers to remove the seal.
Then I used a seal driver and a very large socket to install the seal.
I thought replacing the rear main seal was easier than replacing the seal
on the front timing cover. I found it to be a pain to get that one off.
I did the front while installing my cam.
GM has redesigned the rear seal, it's different from the original unless
you get a Felpro it will be the same. I ended up with the GM seal...
so far so good after almost a year.
Old 08-31-2009, 08:44 AM
91RS383's Avatar
It was very easy to change by removing the cover. I did not need any special tools.
