Annoying Squeak
Annoying Squeak
ive got a bad squeak that appears to be coming from the passenger side on the front. the squeak occurs while driving at any speed or rpm, but not at idle. the squeak appears to stop when i brake, so i thought maybe it was a stuck piston or a clip. i swapped the ls1 brakes into the car had it aligned and whatnot and it still squeaks like crazy. when i had the car dyno'd, i heard no squeak so that confirms that the squeaks coming from the front, or it means its a suspension issue? any info is much appreciated
