6.0L Heads milled .038, shorter pushrods?
Im putting a set of Aluminum 6.0l Heads on my 2000 SS, they have been milled .038, i have a Comp 218/218 .563 114lsa cam, will I need to get shorter pushrods??
Re: 6.0L Heads milled .038, shorter pushrods?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSPope:
<strong> Im putting a set of Aluminum 6.0l Heads on my 2000 SS, they have been milled .038, i have a Comp 218/218 .563 114lsa cam, will I need to get shorter pushrods?? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My feeling is probably not, but you can get a pushrod length tester and make sure. Or just try out your current pushrod and make sure it's the right length, if not, get different ones.
I have 5.7L Cartek heads with .40 off. My cam has simmalar lift n# to yours and Cartek sugest I go with 7.350. Stock length is 7.400.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> I have 5.7L Cartek heads with .40 off. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Oopps- .040 off, not .40 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
You should just buy a bigger cam and then we can measure the base circle on it. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> As long as the base circle is .06 smaller than stock the 7.4's should be fine. The cam really wouldn't be a lot more work than just the heads.
