Where do you connect a digital speedo?
Old 09-04-2009, 09:23 PM
lowbirdws6's Avatar
Default Where do you connect a digital speedo?
I just bought a digital speedo/tachometer from autometer and my question is: Does anyone know where to connect the orange wire that is supposed to connect the +5 volt dc square wave signal (VSS) to the ECU cruise control module, or there is a violet wire that can be tapped onto the hi-side VSS signal on the PCM. The violet wire seems to be the one I would want to hook up but does anyone know which wire that would be on a 2001 trans am pcm? Thanks for any help that can be offered!
