69 Nova LS1 Swap
Old 09-06-2009, 11:01 AM
69Nova's Avatar
Default 69 Nova LS1 Swap
Here is a page to check out my 69 Nova and some up to date photos.
http://musclecarflorida.ning.com/profile/ThomasQuinn
Old 09-06-2009, 01:40 PM
V8Rumble's Avatar
Nice project...
Old 09-06-2009, 02:14 PM
72Elkytpi's Avatar
You should clean the motor up a bit and remove the rust, but looks great.
Old 09-06-2009, 02:19 PM
69Nova's Avatar
Default I plan on it
I plan on cleaning up the motor I am goint to pull the stock crank pully and clean it up. I also plan on pulling the coil packs and having the valve covers powder coated. When all is said and done it should look and run great. I am hope to make 375 to 400 to the rear wheels and have a clean looking swap. Just getting started and also the Nova will be in the body shop for atleast another month or so due to the fact I found some sweet rust and have to replace my drivers side rear quarter now.
Old 09-07-2009, 07:41 AM
forcd ind's Avatar
is it a pass car engine, or truck-curious as to the front acces. drive, F body?
Old 09-07-2009, 11:08 AM
69Nova's Avatar
Default Hey
Its a 99 Z28 Camaro motor the guy I gought it from had all the paper work to document that the motor and trans had 60k on it and the car it came from.
