02 extensions
Def don't rig up your own. You can and chances are it will work. But I wouldn't. A really good option is to go get new O2 sensor, the REAR O2 from a 2003-04 Corvette will work perfect. Not only do you eliminate the need for extension and getting inaccurate readings with all those clips or cutting and crimping, but you also replace your O2s at the same time!
