Any way to test the Coils ?
At what point do we need to replace coils ?
I wanted to test them and see if they are working 100%.
Im doing a spark plug/wires change so its the perfect time.
Thanks for any help
Thanks for any help
Use a spark tester... it looks like a spark plug with a ground clamp on the side of it... you clamp it to a suitable ground and run the plug wire to it... it has a large "gap", the spark should be able to jump the gap easily, looks big/blue/fat if it's good.
Or if you know someone with a high-resolution automotive oscilloscope (and a capacitive secondary probe and a current clamp probe), you can get him to scope your secondary kV and the primary current... the waveforms will show if the coils are working right or not.
