Leak but no fluid on the floor ??
Old 09-09-2009, 07:34 PM
SpinsB's Avatar
Default Leak but no fluid on the floor ??
Stock t56 stock master and slave. Bleed the master two weeks ago clutch felt better but still soft. Went out last night to look things over and the resivor for the clutch was almost empty after just being topped off when I bleed the system. So I filled it back up took a cruise(100miles) checked it the next day and same thing low on fluid but no visible leaks. Not a single drop on the floor or even a drop waiting to fall. ???? Its got to be going somewhere
Old 09-09-2009, 07:40 PM
NovaCain383's Avatar
Check inside the car around the pedals. May be leaking inside the car on the carpet and stuff. Not hitting the ground.
Quick Reply: Leak but no fluid on the floor ??
