2004 Nissan Murano Transmission with crack in shift lever
Old 09-10-2009, 11:07 PM
donnelfrane's Avatar
Default 2004 Nissan Murano Transmission with crack in shift lever
Good Evening All,
Any opinions on the following matter would be greatly appreciated.
I drive a 2004 Nissan Murano that I bought used earlier this year (at 90,000 km at the time). A transmission specialist recently had a look at my transmission (for an unrelated issue) and noted a crack in the shift lever. I’ve attached a photo at this link: Photo of Crack in Shift Lever
I’ve been advised by the transmission guy that there are three options:
1)Replace the entire transmission. Apparently, because it is internal to the transmission, the shift lever is not a part that is sold separately and the entire transmission would have to be replaced . This solution will cost me somewhere in the vicinity of $3000.
2) Weld the crack on the shift lever. This will cost me nothing and will buy me some time before the shift lever fails.
3) Do nothing and hope it holds out for a long time.
If there’s anybody out there who has had a similar experience, or can just offer a bit of advice, please do not hesitate to pass on your thoughts.
Thanks,
D
Old 09-11-2009, 03:26 AM
STG
STG's Avatar
I dunno about it being internal to the transmission... looks like it's held in with a clip? Or do they just not sell a replacement part? I guess welding seems like the best solution.
Nissan, huh... Did you use the launch control?
Old 09-11-2009, 05:49 AM
CarsandWomen's Avatar
weld it and find one in a junk yard....... maybe not easy to find but the weld will give you time and it wont be anywhere close to 3k
Old 09-11-2009, 11:25 AM
twitchtwice's Avatar
i say weld it. i dont see a weld snapping off anytime soon anyways.
Quick Reply: 2004 Nissan Murano Transmission with crack in shift lever
