Clutch is hittin the floor?????
Old 09-12-2009, 10:09 AM
Red Haired Goat's Avatar
Default Clutch is hittin the floor?????
ive got a 04 gto and just the other day the clutch just started sinking to the floor and it got worse fast... i checked my fluid and it was bone dry.. i filled it back up and bleed it and still nothing. people ive talked to say its the slave and some say the master cylinder... HELP!
Old 09-12-2009, 12:54 PM
99ssleeper's Avatar
This should go in the Manual section. But if theres no fluid there then it must be going somewhere...any leaks? Have you looked under the car to see if its dripping? Could be the line from the master to the slave...or the slave itself may be leaking and the fluid is sitting inside the bellhousing. Any abnormal smells? You should see the fluid dripping somewhere though if it's not the slave cyl.
How many miles on this? Stock clutch and hydraulics?
