4l60e question need an answer
Old 09-13-2009, 06:21 PM
bigboy t/a's Avatar
Default 4l60e question need an answer
When installing the tourque converter do you fill up the tc before installing it or does it not matter... thanks for your input
Old 09-13-2009, 06:40 PM
LS1Tech Sponsor
performabuilt's Avatar
Its certainly not a bad idea to try and get a little fluid in it you will not be able to get it full . However 1/2 to a quart should be fine. Truth is the pump will fill it up instantly on start up . But puttng some in may give a little lubrication for those few seconds and keep you from evacuating the pan on start up
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
