Leaky braided stainless lines HELP QUICK
Hey, I'm in the middle of putting on some Earl's lines and I cannot get them to seal at the calipers. I used new washers and re-used the stockers. I cleaned the surface pretty well.
I need help, please reply quick.
Clean the surface *extremely* well. Make sure you use *new* copper washers on both sides of the banjo fitting and tighten properly. My goodridge lines were torqued to 14ft lbs I believe.No leaks here.
