Stumped!! Idles fine, but when when you open the TB it kills??
Old 09-15-2009, 10:52 AM
ctsfiveseven's Avatar
Default Stumped!! Idles fine, but when when you open the TB it kills??
LS1 H/C motor
Changed plugs, they looked good. Only thing is I am not sure if I have the pass side coil packs hooked up right this time, the harness seems to go either way, but I am pretty sure I do as it idles real nice.
It had this problem a bit before I changed plugs it would hesitate and miss off a stop light until you got into the throttle a bit more and it would come out of it.
Mass air?? Crank sensor??
Stumped.....
