Adjustable LCAs
Old 11-29-2003, 08:59 PM
Wicked's Avatar
Default Adjustable LCAs
Could someone guide me thru the proper way to adjust these or give me a link. I threw on some poly/poly BMR LCAs and just wanna make sure everything is setup exactly as it should b.
TIA
Wicked
Old 11-30-2003, 02:02 AM
trackbird's Avatar
Just make them the same length as stock. I use the factory bolts through the stock arms to line up the new ones and lock them down. Then simply install and drive the car. However, make sure that the axle is sitting on jackstands when you tighten them. If the suspension is not loaded (axle on jacks when you tighten them) they will usually squeak constantly. If you do it on jacks, it seems to depend on the car, but the squeaking will usuall be "less".
Good luck!
Old 11-30-2003, 02:45 PM
98DroptopSS's Avatar
Several magazine currently have the install info
