4.10 gears installation kit?
Old 09-15-2009, 10:51 PM
sspower23's Avatar
Default 4.10 gears installation kit?
Anyone did a gear swap to 4.10s? What ALL did you buy with the gears? The complete gear installation kit costs around $123 and the gears cost $225.
Just wanna know if I need the whole installation kit or parts of it? Well which parts? Thanks
Old 09-16-2009, 11:14 PM
Intercooler2's Avatar
Trying to go cheap? You know how that usually ends up.
Old 09-17-2009, 12:38 AM
Josh18Fan's Avatar
If you plan to buy gears and an installation kit, check out Thunder Racing's gear package. $399 with everything you need and a few extra goodies.
http://thunderracing.com/catalog/?ac...&vid=3&pcid=68
Old 09-17-2009, 11:11 AM
01ssreda4's Avatar
The thunder kit is nice. If you don't want to rebuild the rear end you can just buy a shim kit for cheap. I personally wouldn't reuse bearings. Opt for the master kit and refresh the whole rear end.
Old 09-21-2009, 12:19 PM
fatmat80's Avatar
x2 01red22a4
Old 10-28-2009, 01:45 PM
CamaroSS01SLP's Avatar
Does Thunder Racing have a Master Kit or where would you guys recommend I get a "refresh kit" to make my 10-bolt feel as "new" as possible & within spec?......
Old 10-28-2009, 04:07 PM
01ssreda4's Avatar
I believe the thunder kit is $399. It includes a master Ratech rebuild kit, Motive gears, and a TA aluminum rear cover.
Btw, I have always used ratech's kits with good success so far.
Old 10-28-2009, 04:31 PM
Spartan7's Avatar
I went with the Ratech deluxe kit as well. I didn't get the TR package, because I didn't feel like spending extra money on the cover. The Ratech kit comes with all bearings, shims, and seals that you will need for a complete gear install. The bearings are good quality too, mine came with Timken, Koyo, and Torrington. I'd get a Fel-pro gasket to replace the crappy cork one that comes with the kit though.
