various LS1 block bolts/hardware
If you've got this stuff laying around and you don't need them, I DO NEED THEM, help a brother out!
-(10) intake manifold bolts
-(4) coolant cross-over tube gaskets/grommets
-(4) coolant cross-over tube bolts
-(4) fuel line bolts that bolt to the manifold
-(x?) motor mount bolts, the ones that fasten the mounts to the actual block
