Strange SA fronts
Strange SA fronts
My car is stock suspension except for sfc's, Competition Engineering rear shocks set on 50/50 and an air bag in the right rear. I run M/T Et Streets 26x11.5x16 and the car gets 1.6 60 fts and hooks pretty good but I think it should 60ft better. Was wondering if changing to the Strange SA shock and spring setup would help with weight transfer and 60 ft times. Anybody have any info and results from going to a drag shock in front. Thinking a 325lb spring, any ideas?
LS1Tech Premium Sponsor
I would use a 300lb spring not the 325lb. Honestly the Strange SA drags shocks would make a pretty substantial difference on your car. The Strange shock will allow the car to transfer weight much better than the decarbons you have on the car now. If you have any questions just give us a call at the shop it will be easier to talk about your combination. (813)986-9302
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
