Ignition timing
Old 09-22-2009, 10:28 PM
Tensec94z's Avatar
Default Ignition timing
How is everyone taking timing out of their engine,on the bottle,on LS based motors ???
Old 09-22-2009, 10:47 PM
kinglt-1's Avatar
i will be pulling timing via the hsw interface, soon as its installed. You can only pull 3degrees tho, unless the iat tables are modified via hp tuners.
Old 09-23-2009, 08:17 PM
dnkynrbk's Avatar
HP tunners
Old 09-26-2009, 02:35 PM
jman54002's Avatar
I use a timming tuner
Old 09-26-2009, 03:57 PM
JAX04's Avatar
iat tricker device, very cheap, easy and effective!! search, IAT TRICKER , youll get all the info you need
EDIT:::::
https://ls1tech.com/forums/nitrous-o...tor-trick.html
