Does a 12 bolt require a new driveshaft
Old 12-02-2003, 02:10 AM
maddboost's Avatar
Default Does a 12 bolt require a new driveshaft
I was wondering if a new 12 bolt, probably a Strange one, requires a new driveshaft? I heard that a 12 bolt is a different length than the stock driveshaft. Also how tough is the stock aluminum driveshaft?
Old 12-02-2003, 07:35 AM
WILWAXU's Avatar
The stock driveshaft will work with any of the Strange 12 bolts. You'll have to swap out the u-joint for the bigger yoke.
The Moser offers a "billet" yoke. It is longer than the standard yoke. If you use that, I been told you will need a shorter driveshaft.
Quick Reply: Does a 12 bolt require a new driveshaft
