leak at rear e-brake gasket?
Old 09-29-2009, 10:43 PM
hlaalu's Avatar
Default leak at rear e-brake gasket?
Well I'm not sure what this thing is called, but there is a leak at my rear passenger axle from what looks like to be a rubber gasket or something where the e-brake line goes in. Should I put some rtv around there or do I need to replace anything?
Here are some pics:
Old 09-30-2009, 12:50 PM
roy
roy's Avatar
Nope
The axle shaft will have to pulled sothat the axle seal and possibly the bearing can be replaced.
Also may have to repalce the parkbrake shoe and rear caliper pads because of fluid contamination
Old 10-01-2009, 06:18 AM
cambirdracing's Avatar
It's also possible that the caliper is leaking. Check your brake fluid to make sure it's not low.
Old 10-01-2009, 08:52 AM
slayer_taunu's Avatar
ditto them...
its most likely your axle seal
Old 10-01-2009, 09:24 AM
hlaalu's Avatar
Yea pretty sure it was an axle seal, https://ls1tech.com/forums/western-m...ak-coming.html
replaced the seal yesterday
