408 stroker fall special!!!!!!
Old 10-01-2009, 03:06 PM
Xman's Avatar
Default 408 stroker fall special!!!!!!
408 STROKER FALL SPECIAL!!!!!! $3550
The base 402/408 c.i., 6.0L LQ9 iron block, has a Eagle 4340 forged crank, Eagle forged H-beam rods, Mahle forged pistons, with Clevite H bearings, ARP studs and is balanced and blueprinted.
http://www.xhpsolutions.com./product...cat=341&page=1
Options are available for almost every engine combination. Quality part options can be selected from Diamond, Mahle, or Arias pistons; Eagle or Callies crankshafts; Eagle, Callies, GRP, Carrillo rods. If you need a nitrous or boosted build then the upgrades are available for you. A steel top ring should be used for all serious power adders with nitrous of more than a 150 shot or boost in excess of 10 psi.
XHP SHORT BLOCK PACKAGES:
Go here to check out our complete line of LS engines.
http://www.xhpsolutions.com./home.php?cat=341
CALLIES UPGRADED PACKAGES:
These engines have Callies Compstar crankshafts, Callies H-beam 6.125 rods with ARP 2000 bolts, ARP main studs, Clevite H main and rod bearings, all necessary plugs.
402 LS2 Aluminum $ 4490
408 LQ9 Iron $ 3990
418 LS3 Aluminum $ 4890
454 LSX Iron $ 6390
Balanced and blueprinted by our SAM Racing certified machinist using Sunnen Machine Products to produce the best in performance and reliability.
Call 817-503-8947 if you need any help with your application or need a custom quote.
Home of QuickSilver the world's fastest NA pump gas LS1, 9.60 @139mph.
Old 10-12-2009, 07:30 AM
1970judge's Avatar
Too bad college is so expensive, my iroc is begging for one of these! Bump for top notch people!
Old 11-03-2009, 03:12 PM
86montecarloss's Avatar
call for more specials!!
