Sway Bar End Links
Old 10-02-2009, 09:37 AM
Damageinc84's Avatar
Default Sway Bar End Links
I have a 98 TA and my end links are shot and I am looking to replace them. I am looking on summit racing and I don't know which size to get. I guess the front sway bar came in different sizes through the years. Anyone got any idea off hand the size I would need?
Old 10-02-2009, 06:31 PM
leadfoot4's Avatar
The end links are all the same diameter, all you need to do is measure the length of your current links and order the same. The difference in the bar's diameter only matters if you're changing the bar's bushings that are on the subframe.
Quick Reply: Sway Bar End Links
