Lunati voodoo cam #60512
Old 10-05-2009, 09:49 PM
jsafe's Avatar
Default Lunati voodoo cam #60512
LUNATI 232/238 .599/.601 VOODOO CAM #60512
Would this be a good choice for my mods? is it to much?? HELP
Old 10-05-2009, 10:43 PM
Duffster's Avatar
You'll like it Running Lunati 55008 myself (advertised 243/252 .595/.595 112 lsa+4 (108)) but I mic'd it and it's really .600/.601 Got about 9K miles on mine so far and LOVE the pull from 3500+minus the nitrous and my 4.30 rears, near identical.
Old 10-05-2009, 10:48 PM
KRAZY K 2000 TA's Avatar
Default lunati!!
i have run lunati cams in alot of motors and never had a disapointing result that grind should work just fine!
Old 10-24-2009, 06:04 AM
DiabloFormula's Avatar
Look at my past posts...I'm running the 60511 VooDoo with some awesome results.
Old 12-04-2009, 02:52 AM
Ford_Assassin's Avatar
I too am running the 60511 and its an awesome cam.
Old 02-13-2010, 03:52 PM
Mikko's Avatar
Does anyone know, what is piston to valve clearance with this cam?
My engine is stock LS3 (atleast at this point) only 1 3/4" longtube headers, open exhaust and fully programmable ecu. And is it suitable cam otherwise? My dealer suggested this
I dont mind if it doesn´t idle or pull under 2500rm, car is in plain track use.
Or other suggestion from Lunati or Compcams, these brands i can get in decent delivery time?
Old 02-13-2010, 04:13 PM
The only real way is to clay the piston and check it, but I would think it would clear just fine, with th right tuning almost any cam will idle and drive fine under 2500RPM....Lunati does have 3 more in between cam in the VooDoo line, you can find all 6 grinds on ebay, the Lunati site doesn't list the last and biggest VooDoo cam which is 237/243-600/600 113LSA
Old 01-29-2012, 07:04 PM
6SPDN's Avatar
I would like to know also would this cam be good with a set of 799 casting CNC'D and a 383 rotating assembly in a ls1 block?
Old 01-29-2012, 09:19 PM
Herkaleez's Avatar
Default ?????
I would like to know if lunati makes anything of there own....ordered voo doo rockers and link bar roller lifters back in sept. of 2011, jan. 2012 called lunati and they said they were having trouble getting the lifters from MOREL and discontinued the roller rockers due to yella terra couldn't provide them just to sum things up...? is do they even make anything themselves now a days
Old 01-29-2012, 09:27 PM
sepsis's Avatar
Lunati was getting their rockers from Yella Terra? Well that just knocked them to the bottom of the garbage list for me, if true.
I'm gonna have to look into this a bit more.
Old 01-29-2012, 09:31 PM
I know for 100% that they grind their own cams in house.
Quick Reply: Lunati voodoo cam #60512
