LM1 LMA-2 RPM converter TPS and VSS hookup
I have the LM-1 with LMA-2 RPM Converter. The RPM logging works perfectly. I want to log throttle position and MPH.
Is there any trick to doing this? It looks like I need to tap into #24 on C2 for the TPS signal and #21 (high signal) C2 for the VSS. #20 is the VSS low signal. Does this need to be considered?
Other than adding a ground and configuring the Converter through LMProgrammer, is this all possible just by tapping into these wires from the PCM?
Well, these connections worked except enormous gain (spiking) from the VSS high signal. I was able to smooth it using that feature in LogWorks3 with the maximum setting. Also, with the high signal, 2.35 volts = 160 mph. That seems like quite an offset from the 5v i would have expected.
Now I see just a plain VSS Signal #50 on C2. Anyone know if I should use that instead?
With these working I want to add manifold vacuum. I'm wondering if I should tap into the MAP Sensor Signal - pin #32 on C2 for that. Anyone know for sure???
