How do you guys prefer your tires to be balanced??
Old 10-06-2009, 06:51 PM
k5383's Avatar
Default How do you guys prefer your tires to be balanced??
I was balancing at work today, and it came across my mind. haha
On my vehicles I only balance static (one row of weighs) with tape weights, but if its a steel wheel I much prefer hammer-on weights.
Old 10-07-2009, 07:02 AM
chevroletfreak's Avatar
I do static balancing on the back/inside of the rim so it does not show as much or cause lip damage.
Old 10-07-2009, 08:14 AM
NC01TA's Avatar
I always have the weights placed on the inside of the tire. I really dislike the weights showing on the outside of the rim. If you or your tire/wheel guy are good, the balance will be true and not have to be on the outside.
Old 10-07-2009, 12:59 PM
hitmanws6's Avatar
for our wheels the best balance would be bang on weights on the inside, sticky weights on the outside. static balancing is not a good way to balance.
Old 10-07-2009, 01:20 PM
OK. Why?
Old 10-07-2009, 04:11 PM
k5383's Avatar
I also ask why?
Static works just as well as a "dynamic" way of balancing.
On 99% of vehicles I balance on, I use dynamic with hammer on weights. But my vehicles I use static balance, with tape weights.
Old 10-07-2009, 10:57 PM
hitmanws6's Avatar
Originally Posted by k5383
I also ask why?
we try to use sticky weights as little as possible. they shift or can fall off easily, which means customers are coming back for in warranty balances all the time. on most wheels we use "Alloy 2" on the machine. it insures that the weight on the inside of the wheel will stay on there.
Old 10-08-2009, 12:41 PM
tillery's Avatar
I have never had sticky weight fall off- unless the tech didnt clean the surface before installing them. For me a static balance is fine As long as the tech knows how to do it right the first time. I would place the weight near the center of the rim or as close without them hitting any brake components. But it also depends on what size of tire and vehicle I am driving. My truck a dynamic-because of the type/size being used-More rotational mass.. My TA since its a lowprofile tire a static is fine-less rotational mass. Make any sence?
Old 10-08-2009, 03:06 PM
Jwright41's Avatar
Weird question... how do you place the weight on the inside of the tire and make it stick?
Old 10-08-2009, 03:17 PM
hitmanws6's Avatar
you dont.....you put the weights on the inside of the rim
Old 10-08-2009, 03:25 PM
Jwright41's Avatar
Thought that was worded a little weird but then again I dont know anything about wheel balancing. Gonna have to remember that for my next set of rims.
Old 10-08-2009, 04:06 PM
k5383's Avatar
Exactly, both my 37" swampers and my Michelins on my T/a are both static balanced.
The T/A I did sticky weights down the middle.
The truck I used hammer-on weights static balanced on the inside. (Can't use stickyweights, hits the caliper)
Everything I drive, and most customer cars I balance static. It uses less weights, and to me looks better than having weights on the face of the wheel.
Old 10-08-2009, 04:50 PM
tillery's Avatar
alot of people feel one is better over the other. its not like your doing it the old way with the bubble method. and guessing what weight to use. And some tire/wheel techs dont know that there different style of weights for different style of wheels. Not all wheel rim lip is same.
Old 10-08-2009, 06:50 PM
k5383's Avatar
Yep...we have guys in our shop now that don't know the differences, or how *some* can interchange.
PLus it does not help that the SH*TTY company I work for never orders us enough wheel weights. It gets REAL old having to dig through the old weights looking for what you need.
Old 10-11-2009, 02:45 AM
SnakeStomper's Avatar
I like mine balanced ... correctly
Old 10-11-2009, 07:14 AM
SuperSport01's Avatar
As long as mine are balanced I could care less if I see the wheel weights on the outside.
Old 10-11-2009, 12:18 PM
69z-28's Avatar
on my c6 wheels there is no lip for clip weights so i did mine dynamically with tape weights. no issues
Old 10-11-2009, 05:07 PM
tillery's Avatar
Or how about not having the weight needed and cutting one down to make the one you need?
Old 10-11-2009, 05:57 PM
1BAD02WS6's Avatar
my shop has a road force balancer. I balance my wheels with clip weights on the inner lip and sticky weights on the inside barrel and my machine can actually hide the weights behind the spoke
Old 10-13-2009, 11:30 PM
justout4u's Avatar
Why would you only do a static balance? That is like replacing just the outside brake pads. Just clean the surface of the wheel good, and use sticky weights. Yes you can also hide them behind spoke.
