the actual turbo parts help
okay so I was wondering this for sometime now if you have two turbos of the same make say 1 GT67 and a 60-1 with different exhaust housings say the 67 is a .96 and the 60-1 a 1.15 AR could you swap out the housings? there a way to change out the exhaust propeller if that is needed also?
some turbos can be interchanged as far as housing go, and even wheels although im almost posative after a wheel is changed the turbo needs to be rebalanced. On those particular turbos im not sure if they can be changed, im sure DrTurbo or someone will come in for that.
