Recommendation Needed for What to Delete (or not) in Stand Alone Swap Harness
I'm sorry if this has been answered before but I'm having trouble deciding what to delete in a 5.3 LM7 harness that I'm making into a stand alone for a 69 Camaro 4 speed. First, I've already deleted the evap. switch wiring because I have a LS1 intake that doesn't have the switch. Since the car is a standard, I want to delete all the automatic trans wiring but am afraid something in there may be needed by the PCM even with a standard. Also, what about VSS? I may want to enable cruise control later but not sure what I can get away with deleting. The car has AC that will work fine w/o any PCM connections but???? Hopefully, someone will see this that has done these before and can recommend what to leave and take out. Thanks all...
