Switch suggestions
I have my 2 step and line lock on the same momentary switch mounted to the shifter. The 2 step has a toggle in line between the box and momentary switch. This way I can have the toggle off and use the line lock for burnouts, then turn the toggle on for line lock and 2 step at the starting line. I would guess you could do something similar with your T brake.
