single turbo with a/c & p/s
ok so was looking at making my own hot side out of scratch using the truck manifolds but after seeing a couple of the builds with this set up i saw nobody ran a/c and thats a big issue for me here in yuma az specially cause this is my d.d. so i was looking at the ebay kit http://cgi.ebay.com/ebaymotors/01-02...Q5fAccessories
and it seems to use a diffrent routing but it looks like id be in the way of the power steering and the alternator so i was wondering what i would have to do to make this work i want all my accesories i will be running a lq4 with a t76 turbo
Usually the Alternator has to be relocated for almost all the kits out there.....
You CAN however keep the AC if you use a C6 Vette Manifold on the Passenger side....WS6Hummer did it this way... Have a look....
https://ls1tech.com/forums/forced-in...old-setup.html
