Remove the 10 bolt rear????
I'm attempting to remove the 10 bolt rear this weekend out of my camaro. I just wanted some advice and info on the type and size of tools I'll most likely need. Any good tips would also help. Should be getting the 12 bolt soon.
lift the back of the car by the pumpkin of the rear end, place jackstands on SFC's or wherever you want them at. Lower car onto jackstands, but leave the suspension under a load with the jack. Unbolt everything. Lower the jack again, and watch the rear come down.
18 mm, 21mm, 22mm.
18 mm, 21mm, 22mm.
