Advice on cam to choose
Old 10-17-2009, 12:20 PM
reddevilSS's Avatar
Default Advice on cam to choose
Hey guys, I am about to start bumping up the Hp's in my 99 camaro ss and thought I would get your advice first. The car is ready for power but needs to maintain semi daily drivable attributes. I just installed the Moser 12 bolt (4.10) , custom steel driveshaft, Edlebrock Long tubes, y-pipe, cut-out, SLP flowpack intake with K&N, SLP MAF, Rebuilt transmission, LS7 clutch, flywheel, pilot and throw-out bearing (Slave cylinder too obviously), was tuned about a year ago, sub-frame connectors, Adjustable LCA, and other suspension and brake work. The new rear seems like its slowing me down a bit. Ideally I would like over 400 horses and still daily drive it. I am not sure how long it will be a daily driver but i can't look too far ahead just yet. Any advice on what cam to choose??? I want to hear how they run on already cammed Daily drivers. Thanks for any advice
Old 10-18-2009, 08:44 AM
TransAmcoupe98's Avatar
Well you have a good foundation with the built rear end and tranny. Something that will maintain good street manners but still put up good numbers I think would be the G5X1. LG motorsports' cam series. Proven performers, and will still drive great on the street. Specs are 228/232. Don't get caught up in the dick measuring contest of buying huge cams.
Old 10-18-2009, 09:06 AM
01ssreda4's Avatar
tr228 or 228r.......
Old 10-18-2009, 10:15 AM
allngn_c5's Avatar
VRX3 or 4, just give Ron@Vengeance a call. He'll explain your options in detail.
Old 10-18-2009, 10:48 AM
hammertime's Avatar
A good tuner can take any of the recommended cams above and make them drive very smoothly. All the suggestions are on the right track. Bigger cams are fine for track only cars or hardcore weekend warriors, but anything that needs to start and run smoothly 7 days a week can get old in a hurry if your get caught up in the giant cam fad.
Good Luck!
Old 10-18-2009, 11:18 AM
thewholefnshow1's Avatar
Torquer 1 or 2 or maybe flowtech streetsweeper cam and as said above VRX3 or VRX4 I run a cam somewhat similar to a VRX3 in my sigs
Old 10-18-2009, 11:40 AM
stumprrp's Avatar
get a custom cam, my 230/236 114 drives perfect on the street. i would go with a 111 if i did it again though, that would probably change it all.
