Detailing/Cleaning New Black Vehicle
Just as the title states, I was wondering what everyone's opinion on cleaning a new vehicle, that's black. I don't like the swirl marks that you get even if you do a hand wash. It seems always to do some minor damage that you can see in the daylight. Is it just Wax Wax Wax? Or???
Help!
Help!
Supplies:
-car wash soap with high lubricity
-high quality sheepskin wash mitts
-foam gun (optional)
-2 buckets with grit guards for paint
-1 bucket and mitt for wheels
-high quality microfiber towels
-210+ mph electric leaf blower
-high quality sealant and/or wax
-quick detailer
Method:
-Wash wheels/tires/wells first to prevent spotting on paint and glass
-Don't use the same mitt or bucket for wheels that you use on your paint. The brake dust, etc. from your wheels will cause scratches and swirls in your paint.
-Using foam gun, cover vehicle in a thick layer of foam (optional)
-Use two buckets for washing paint. One with a soapy mixture, the other with plain water to rinse the mitt between panels.
-Never use circular motions. Always wash, dry, and wax using front to back and top to bottom motions.
-When vehicle is fully cleaned, allow a slow, steady stream of water to flow over each panel...sheeting the majority of the water off
-Use the leaf blower to blow all water from flat surfaces, mirrors, lights, etc.
-Remove any remaining water with a waffle weave drying towel and detail spray
*The less you touch the paint, the less chance of marring*
Keeping a good sealant and/or wax on the paint will assist in cleaning and reduce chances of marring.
-quick detailer
Method:
