4.11 in stock 10 bolt
Old 12-05-2003, 07:21 PM
BananaNutz's Avatar
Default 4.11 in stock 10 bolt
how long will 4.11's last in a stock rear end, assuming i get a stud kit and a TA cover?? i rarely go to the track, i never even went this year.... i run stock goodyear tires....
Old 12-06-2003, 08:32 PM
timelord's Avatar
Could last forever if you don't HIT it.
Ran my 10 bolt with 4.10 most of last year without a problem,
would still be there if I hadn't run across the deal on the 9".
Old 12-10-2003, 01:34 PM
KGSloan's Avatar
if you stick with stock radials you will be fine. you'd probably even be fine with nitto's but you're pushing it, especially nitto's at the track. with stock goodyears, i would not worry about it breaking
Old 12-10-2003, 01:37 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
doing fine here with nittos, but saving for a 12bolt or 9inch. really babying it around as much as possible, and there's no fun in that.
Old 12-12-2003, 06:09 AM
mcflyz28's Avatar
On stock tires all they do is spin,I borrowed some BFG's it definetely did not like that thought it broke but boy what a difference.
Old 12-13-2003, 09:25 PM
skippytheloon's Avatar
Stock goodyears. so far 6,000 miles on them no problems at all....yet. If my rear blows, I'm straight screwed, but I'm not too worried since I'm just peeling out in the first half of the gears!
Old 12-14-2003, 03:45 AM
Smoke_Ford's Avatar
When you start adding components like LCAs, sticky tires and other suspension mods that provide for better traction, then you are gonna reek havoc upon your rear end.
