Couple questions before spraying first time
How long does it take you guys to heat your bottle up? Say from 650 to 950.
Also what kind of mph gain roughly will I see from a 100 shot. Mods are headers, intake, 4400 converter. It has trapped 109. Just making sure I'll have enough room to keep it in 3rd with 5900 shift points.
Im running a nx kit and the time it takes to heat the bottle depends on the starting bottle temp. When I first got it it was maybe 65-70* out and to raise the pressure from 650- 1050it took maybe 10 mins but recently its been aroun 45-50* and even with a blanket wrapped around the heater and bottle it takes a half hr atleast to raise the same pressure. As far as trap speeds my s-10 is slow but you can read my sig to see the increase and that was having to let off for it to shift into 3rd since it wouldnt shift on its own under wot for some reason that run. Looking at my hptuners scan it showed I let off for a little over a second before I got back on it.
