Idle relearn anybody???
Old 10-22-2009, 06:59 PM
69chvl468's Avatar
Question Idle relearn anybody???
Can't get my ls1 to idle. I keep hearing idle relearn, anybody know how to do this? I drove my car around for an hour, still not any different. It dies going into gear and at a stop sign. Anybody?
Old 10-22-2009, 07:03 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Engine on, then off repeatedly, will help it learn.Not just driving around.
Old 10-22-2009, 07:09 PM
69chvl468's Avatar
Ok thanks, i heard pulling ignition and batt fuses with key on? Then turn off key and replace fuses. heard of this?
Old 10-22-2009, 07:13 PM
jjcamaro02's Avatar
Try unpluging IAC turn key to run position don't start then turn key off.Plug IAC back in
start car,if that does not work car may need to be tuned.
Old 10-22-2009, 07:43 PM
eseibel67's Avatar
Idle relearn is the PCM figuring out how many IAC counts to apply for various conditions.
It will only learn idle when you are idling. Try different combinations of park/drive and AC on/off. Do each combo for 10 seconds.
