Which is better wet kit or dry for LT1 up to 200 shot?
Old 10-22-2009, 07:12 PM
97Z28SS's Avatar
Default Which is better wet kit or dry for LT1 up to 200 shot?
Hey folks I have an all 4340 forged LT1 with LE heads & intake, cam LTs & TDs thru an M6 and S60 rear. I am new to spray and I want to know which is better on an LT1 "wet" or "dry" nitrous up to say a 200 shot?
Old 10-22-2009, 09:21 PM
n2ocamaro's Avatar
Wet from what I've heard. Check out Harris Speed Work's and Nitrous Outlet's wet kits for LT1's.
Old 10-23-2009, 07:05 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Well at the 200 hp shot level, you should be looking beyond plates or nozzels in terms of even distribution. #1 cyl in LT1's tend to get starved to begin with. Personally I would not run a dry shot past 100 hp as the requirement to supply the added fuel makes the A/F too rich for my blood and I am not a fan of fuel swaps at the track.
I would personally run a direct port wet shot running off a stand alone filled w/ C16 so the safety margin is there and your "street" tune does not have to be toned down as much. It would give you a good balance IMO.
Old 10-23-2009, 11:37 AM
Ph.D. in HUBRIS
custm2500's Avatar
I would say wet is your best bet. Plenty of guys like dry but wet systems are easier in my opinion especialy when you get higher in the HP.
Old 10-23-2009, 11:45 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
For the LTx application I would suggest a wet also.
Quick Reply: Which is better wet kit or dry for LT1 up to 200 shot?
