Is a 90mm Throttle body worth it??
Old 10-24-2009, 08:29 PM
Boosted One's Avatar
Default Is a 90mm Throttle body worth it??
I'm going to be using the new Edelbrock Pro Flo XT intake for my upcoming turbo project and I'm trying to decide if I should just bolt my ported stock throttle body on there or go ahead and buy a 90mm for it. Since we are shoving the air in there anyway, is it worth the cost of admission for the 90mm???
What's your opinions?
Thanks,
Frank
Old 10-24-2009, 11:27 PM
TheFallen's Avatar
if you have the funds by all means pick one up. But if youre only running 3" pipe to TB then there is no sense in using a 90mm. if you use 4" to TB then yes use 90mm. i run 4" to the TB and use a 90mm tb
Old 10-25-2009, 12:10 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Port the stocker and save the cash. Plenty have put up great numbers with the ported stocker.
Old 10-25-2009, 10:49 AM
veee8's Avatar
I have made over 1000hp and been in the 8's on a 78mm FAST TB.
Old 10-30-2009, 10:01 AM
Orr89rocz's Avatar
I got 3" pipe feeding stock LS1 throttle body on a victor EFI setup on a twin turbo small block 401 and its been 10.3's at 134-135 so far, 3500 lb with me in it. Weak launch and rough street tune, only 10psi boost
Ported stock TB should be plenty
Old 10-30-2009, 10:42 AM
z28boysteve's Avatar
So my 105 is a bit unwarrented ? lmao with originally a 2 1/2 feeding it!, Will be 4" shortly when I make it home from Iraq again and fab a new cold side.
Old 10-30-2009, 12:41 PM
BlwnLs1GTO's Avatar
This is good info.
I'm running two 66's thru a 3" expanded to 4" pipe just before the stock LS1 TB. I've been worried that it would be a big restriction. The goal is 800whp with the 403ci.
Old 10-30-2009, 12:49 PM
Orr89rocz's Avatar
Yeah i think you can make good power through a stock LS1 throttlebody. Ported wouldnt be bad idea tho, I just dont think i'd justify the big mm TB's unless you have a setup using 3.5-4" feed pipe. I dont, just 3" so stock $50 TB worth it to me low 10's, mid 130's with more in the the tune for sure and just 10psi boost
Quick Reply: Is a 90mm Throttle body worth it??
