Thanks FLT and Circle D 1.63 60ft stock suspension w/ Front swaybar!
Old 10-25-2009, 10:03 AM
355z28's Avatar
LS1Tech 10 Year
Default Thanks FLT and Circle D 1.63 60ft stock suspension w/ Front swaybar!
Just wanted to say thanks guys. The car ended the year on a good note running my new personal best at 3500lbs, stock suspension with the front sway bar. 60ft was a 1.63
Andy, Vince and Chuck this trans is amazing I couldnt be happier!
Chris this converter with Hoosier QTPs was deadly at the track!
Old 10-25-2009, 03:41 PM
FLT
FLT's Avatar
Thanks for the update. What was you mph and your et?
Old 10-25-2009, 08:09 PM
355z28's Avatar
LS1Tech 10 Year
The car is 3500lbs with draglites.
Its cam only, stock heads with a 11.5:1 cr the cam is the lt4 hotcam 218/220 with .525 lift.
time slip was:
1.63 60ft
7.75 1/8th
12.25@109mph.
My sig is the setup that will be on it next year!
