102 mm fast
Old 10-25-2009, 03:27 PM
lsx440's Avatar
Default 102 mm fast
can you run a 102 mm fast intake and tb on a lsx440 thanks
Old 10-25-2009, 03:31 PM
jdiddyws6's Avatar
Sure, as long as they are square port heads, or you could run the 102 rt on cathedral heads.
Old 10-25-2009, 03:33 PM
G Engines's Avatar
No the biggest one that would fit your heads is the 92mm intake
Old 10-25-2009, 03:34 PM
jdiddyws6's Avatar
Sorry, missed the lsx, i was thinking ls7
Old 10-25-2009, 03:35 PM
lsx440's Avatar
do you know a link to that manifold
Old 10-25-2009, 03:38 PM
jdiddyws6's Avatar
Depends on the heads you are gonna use?
Old 10-25-2009, 03:42 PM
lsx440's Avatar
i have 235cc trick flo
Old 10-25-2009, 03:45 PM
jdiddyws6's Avatar
So, I'm pretty sure you can use fast 92/102 rt,or a single plane.
Old 10-25-2009, 03:46 PM
lsx440's Avatar
ok thanxs
Old 10-26-2009, 02:34 PM
Apollo0526's Avatar
whats the 102 rt?
Old 10-27-2009, 09:08 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
You need the fast 92mm intake. We offer a ported Fast 92mm intake moded for 95mm throttle body. The 95mm throttle body, intake & porting is right around $1300. You can check it out on our site, or give us a call!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
http://www.texas-speed.com/shop/item...d=982&catid=73
__________________
Jason
2005 Twin Turbo C6
