Wheels stud size
Old 10-26-2009, 03:38 PM
litch2004's Avatar
Default Wheels stud size
i will be running 15x10's with 7.5bs and 15x3.5 with 1.75bs. What size wheels studs would be recommended? i will not be using a spacer and i will be running open ended shank lugs nuts.
Old 10-26-2009, 08:01 PM
litch2004's Avatar
t t t
Old 10-26-2009, 08:19 PM
trigger1's Avatar
You can run arp's 12mm 3.25 stud up front, which is what I use. Out back I run a 5/8ths stud, but I'm going to assume our application/goal/use is a bit different. Depending on how hard you plan to hook the car, I would look at maybe upgrading from the available 12mm arp stud in the rear.
Old 10-27-2009, 10:42 PM
litch2004's Avatar
im going with the ARP front and back. but needeing the length fot the front and back so i can get them ordered
Old 10-28-2009, 05:47 PM
trigger1's Avatar
I would just toss 3.25" in the front and rear.
Old 10-28-2009, 10:01 PM
litch2004's Avatar
ok sounds good. Im still waiting on my race star industries 15x10's to come in but id like to be ready. Even if i am running the stocks on there with long studs for now.
