6.0 in a 68 Camaro
6.0 in a 68 Camaro
I need ideas and info. swaping a 6.0 LS based motor in a 68 camaro, I currently have a 6.0 truck motor complete with all accesories and ECM. the goal is 600-650 hp if possible. a supercharger is not out of the question or possibly stroking it. I do not want nitrous. will the truck accessories work in the camoro? I need to retain A/C also. I realize it will need heads, cam and blower or heads cam and stroker to reach the 600-650 hp range. what is my best option? the trans is a built 700R with manual valve body. thanks
You will have to notch the frame a bit to get the A/c to clear, but not much.
You will need a few other pieces to complete this project as in: motor mount adapter plates, headers, oh and we can help you with a custom harness that will fit your motor in your car vs making one work out of a truck if you decide to go that way. Our harness builder lets you decide where you want the PCM to be located in your car!!
