need help with wierd emergency brake issue
so i go to pull in the car into the garage recently and go to pull up the emergency brake and it felt so easy to pull up and it went straight up into like a 90 degree angle. has this ever happend to anyone before? what do you think the problem is?
Save the manuals!
This happens when you change rear rotors and don't re-adjust the brakes to the new bore of the rotor. (There are two adjusting wheels under each of the rotors, where each side gets adjusted individually.)
If the rotors havn't been changed out at any time, then something else in the mechanism could be broken.
