Ok...Narrowed it down to two kits... Help me choose!
I have narrowed down my search for a nitrous kit down to two options...
Its for a automatic LS1, Walbro 340 pump, 42# injectors... I'm looking to go as fast as possible, as safe as possible...
Now, I know one is dry and the other is wet...
I was interested in the HSW Sudden Impact Dry plate kit;
I was interested in a dry shot due to the interface advailable to tune it
-OR-
Nitrous Outlets 98-02 Fbody specific plate kit
Interested due to fitment for the car
What I was looking for on answers was;
How do I tune for the wet nitrous kit? trial and error in fuel/nitrous solonoids?
Can I still use an item such as the HSW Microedge interface with a wet nitrous kit?
And just which would you recommend and why?
-OR-
dry vs wet is up to you, but both the kits will get the job done. It seems like you have the fuel system for the dry shot though.
I would think you tune both the same way though. Start small like a 100 shot get that dialed in and work your way up. A good wideband air fuel meter would be super helpful if your doing the work yourself, or you could get a good tuner to dial it in for you.
An I've heard you can use a interface to fine tune a wet kit by using the injectors to add extra fuel, like if you were using a 150 wet kit and wanted to spray 200, you could just change the nitrous jets and set the interface to add the additional fuel with the injectors.
What other mods do you have and what size shot were you looking to go with?
To answer your questions, you would tune the wet kit with the jets. And yes you can also run the Interface with a wet kit. You can use it to dial in the fueling as well as pull timing.
Shoot me a PM, I'd be more than happy to discuss your build with you and get you going in the right direction. Thanks.
Nick
Nick
I'm looking to hit it with a 150 shot realisticly... but to start, a 100...
ALSO... I am getting a new rear... should I change my gearing down to the nitrous?
Personally I prefer the wet system when using the factory GM PCM. Ofcourse everyone has there own opinion. With our Vehile specific wet system the fitment is very very simple. The system comes already assembled. All you have to do is bolt it in place. You will not need to but extra fittings or hoses to try to clean the look up. With our fuel solenoids you can run strait E85 if you wanted to. They are designed to work with todays fuels.
Tuning with our wet plate system is easier than any other system. You simply just switch out the fuel jet to adjust the air fuel. Takes about 30 seconds.
Our plate system is capable of flowing up to 400 hp out of the box. So it is something you can grow with. Do a search there are plenty of customers using our plate to spray 250 hp and some are at 300. In order to be able to supply these type of horse power levels through the front of the intake the design has to be exact. We will let the results you find from our customers speak for itself.
So the answer is..
If you want a sexy looking system capable of safely supplying the HP you want now and later with the easiest tuning possible the answer is our wet plate system. Plus they are on special until the last day of October for only 599.99
Dave
So the answer is..
Dave
Dave
42's should be good to a 150 shot. Wet or dry both have their advantages and disadvantages and technically neither will be better for any one person so it would be silly for me to always say one thing. In your case for the goals you posted with the equipment you're running a dry shot would do the trick and very effectively. Another advantage you need to consider is that you can also pull timing with the Interface. This is a huge advantage for the guy that wants max n/a power coupled with the ability to run efficient timing on the bottle.
If you do consider going wet...keep goofy connectors and 90* bends out of the equation. There is enough of them already in the solenoids and the last thing you need is to hinder flow in any way.
Nick
Nick
Nick Wouldnt you agree though that they should concider the fact if going dry they will hit a point to where they have maxed out the mass air meter. I recently had a customer of yours that had a heads and cam car hit a wall with the interface due to how it works.
In order for him to continue to use that item he would have had to make tuning changes that would alter his daily N/A driving.
Since this guys already has a stick in the car there will be apoint depending on how much he wants to spray that he would hit the same problem..
Agree or disagree?
Dave
Agree or disagree?
Dave
I am very concerned about maxing out the mass air sensor.
I would want to do this right and do it the first time...
I know I will have to pull timing, and thats why the Microedge controller was attractive to me, I know I will have to do plugs, Thats not an issue...
