2000 10 Second Camaro Z/28
Old 10-29-2009, 11:55 AM
FBTuner's Avatar
Thumbs up 2000 10 Second Camaro Z/28
Hey guys, not quite sure what she's worth.
2000 Camaro Z/28 Hardtop w/ cloth interior
97,000 Miles
SS Hood and Deck Lid
Weld Prostars 165's in the front and 28x10.5x15 in rear w/ plenty of tread left
5% Window Tint all around
Viper alarm system
QA1 Coilover Drag Shocks and Springs in front
AC removed along with condensor
Optima Battery Reloacted in Spare Tire Area with Killswitch
Torque Arm with Driveshaft Loop
Weld-In Subframe Connectors
Adjustable Panhard
Wolfe Racing Drag Rear Sway Bar
Moser 9" housing with backbone
40 spline axles
Pro gear 3.90
Strange ultra lightweight spool
Moser aluminum center section
5/8s stud kit
8 Point Chromoly Roll Cage
Engine
346
Ported Intake
Ported Throttle body
LS6 Intake Manifold
NX MAF wet kit
stock casting ported heads. (local machine shop/ls1 guru hand ported these, there doing the job nicley)
comp Pro magnum push rods
LS7 lifters
Comp roller rockers
hooker headers
NX stage 3 cam. .600 lift
high volume oil pump
stock bottom end with the exception of Rod bolts
Underdrive Crank Pully
SLP Lid with K&N Filter
Walbro 255lph Fuel Pump
New Fuel Filter
NGK TR6 Spark Plugs
MSD Plug Wires
Tuned with HPTuners
Tranny
TH400
TCI full manual reverse valve body with transbrake
Art Carr built tranny with all the good stuff
Neil Chance 3500 converter. anti balloon plates and all
B@M quarter stick with Transbrake button on ****
Nitrous is NX MAF kit with purge and electronic full throttle switch
Lightning solenoids
15lb bottle
DynoTune window switch
DynoTune bottle heater with pressure sensor to maintain desired pressure
LED Shift Light in Drivers round defrost vent
Exhaust is a work of art, all custom 3" mandrel bent with X Pipe, 2 singe chamber flow masters and dumped at the rear
I'm sure I'm forgetting some stuff, but that should be the majority of it.
I only run a 150 shot on the car.
I have ran a best of 10.48 @ 123.69 with a 1.44 60ft when the car had 4.60 gears
The car now has 3.90 gears in it and runs 10.5's @ 126 with a 1.48 60ft
The car dyno'd 500whp and 500ftlb tq on a 150 shot
Here are some pics and video links of the car.
Let me know what you guys think it's worth
Thanks!
Here is a video of the car on the dyno
[youtube]TufPt_OSQ2w[/youtube]
The car running at the track (it's about halfway through the video my car runs)
[youtube]YM9aL4iGtdk[/youtube]
Quick Reply: 2000 10 Second Camaro Z/28
